Beam Design - Aldworth
Design Span (L): 12.75 ft.
Clear Span: 12.50 ft.
Total Span: 13.00 ft.
Selfweight: 34.2 lbs
Dist. Selfweight: 2.68 plf
Total Weight: 34.8 lbs
Beam Design Carlos Val 1
10/10/2022 1
10/10/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (153.00 + 3)] x (12 in./ft.)3 = 0.98 ft3
Volumespan = N[A x L] = 1 x [10.88 x 153.00] x (12 in./ft.)3 = 0.96 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 0.98 = 34.8 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 0.96 = 34.2 lbs
Distributed Self Weight (ws) = = 2.68 plf
ws = 2.68 plf
12.75 ft.
12.50 ft.
13.00 ft.
1154.91 lbs
1154.91 lbs
10/10/2022 3
Fbx' = (900)(1.00)(1)(1)(1)(1.2)(1)(1) = 1080.0 psi
fb = = 3297.1 psi
 fb = 3297.1 psi > Fbx' = 1080.0 psi  (CSI = 3.05)   ➜  NG
10/10/2022 4
Fvx' = (180)(1.00)(0.97)(1)(1) = 174.60 psi
fv* = = 141.43 psi
 fv* = 141.43 psi < Fvx' = 174.60 psi  (CSI = 0.81)   ➜  OK
fv = = 156.23 psi
 fv = 156.23 psi < Fvx' = 174.60 psi  (CSI = 0.89)   ➜  OK
10/10/2022 5
ΔLL = = 0.87 in.
(L/d)LL = 153.00 / 0.87 = 177
 ΔLL = 0.87 in = L/177 > L/360   ➜  NG
ΔTL = = 1.54 in.
(L/d)TL = 153.00 / 1.54 = 99
 ΔTL = 1.54 in = L/99 > L/240   ➜  NG
fc⊥ = = 256.6 psi
 fc⊥ = 256.6 psi < Fc⊥x' = 418.75 psi  (CSI = 0.61)   ➜  OK
10/10/2022 6
