Design Span (L): 23.75 ft.
Clear Span: 23.50 ft.
Total Span: 24.00 ft.
Live Load: 300 plf
Dead Load: 180 plf
Selfweight: 200.9 lbs
Dist. Selfweight: 8.46 plf
Total Weight: 203.0 lbs
Beam Design 2022A647
9/27/2022 1
9/27/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (285.00 + 3)] x (12 in./ft.)3 = 5.44 ft3
Volumespan = N[A x L] = 3 x [10.88 x 285.00] x (12 in./ft.)3 = 5.38 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 5.44 = 203.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 5.38 = 200.9 lbs
Distributed Self Weight (ws) = = 8.46 plf
300 plf
180 plf
ws = 8.46 plf
23.75 ft.
23.50 ft.
24.00 ft.
5861.49 lbs
5861.49 lbs
9/27/2022 3
Fbx' = (925)(1.15)(1)(1)(1)(1)(1)(1) = 1063.8 psi
fb = = 10483.5 psi
 fb = 10483.5 psi > Fbx' = 1063.8 psi  (CSI = 9.86)   ➜  NG
9/27/2022 4
fv* = = 253.12 psi
 fv* = 253.12 psi > Fvx' = 201.25 psi  (CSI = 1.26)   ➜  NG
fv = = 266.69 psi
 fv = 266.69 psi > Fvx' = 201.25 psi  (CSI = 1.33)   ➜  NG
9/27/2022 5
ΔLL = = 10.73 in.
(L/d)LL = 285.00 / 10.73 = 27
 ΔLL = 10.73 in = L/27 > L/180   ➜  NG
ΔTL = = 17.48 in.
(L/d)TL = 285.00 / 17.48 = 16
 ΔTL = 17.48 in = L/16 > L/120   ➜  NG
fc⊥ = = 434.2 psi
 fc⊥ = 434.2 psi < Fc⊥x' = 565.00 psi  (CSI = 0.77)   ➜  OK
9/27/2022 6
