Beam Design - Wells Deck Beam
Size: 4 x 16
Design Span (L): 19.67 ft.
Clear Span: 19.33 ft.
Total Span: 20.00 ft.
Bearing (lb): 4 in.
Live Load: 256 plf
Dead Load: 64 plf
Selfweight: 245.2 lbs
Dist. Selfweight: 12.47 plf
Total Weight: 249.4 lbs
Beam Design 2022A645
9/26/2022 1
d = 15.000 in.
9/26/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (236.00 + 4)] x (12 in./ft.)3 = 7.29 ft3
Volumespan = N[A x L] = 1 x [52.50 x 236.00] x (12 in./ft.)3 = 7.17 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.29 = 249.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 7.17 = 245.2 lbs
256 plf
64 plf
ws = 12.47 plf
19.67 ft.
19.33 ft.
3324.76 lbs
3324.76 lbs
9/26/2022 3
fb = = 1469.7 psi
 fb = 1469.7 psi > Fbx' = 1035.0 psi  (CSI = 1.42)   ➜  NG
9/26/2022 4
fv* = = 81.54 psi
 fv* = 81.54 psi < Fvx' = 207.00 psi  (CSI = 0.39)   ➜  OK
fv = = 93.41 psi
 fv = 93.41 psi < Fvx' = 207.00 psi  (CSI = 0.45)   ➜  OK
9/26/2022 5
ΔLL = = 0.55 in.
(L/d)LL = 236.00 / 0.55 = 431
 ΔLL = 0.55 in = L/431 < L/180   ➜  OK
ΔTL = = 0.71 in.
(L/d)TL = 236.00 / 0.71 = 332
 ΔTL = 0.71 in = L/332 < L/120   ➜  OK
Ab = b x lb = 3.5 x 4 = 14.00 in2
fc⊥ = = 237.5 psi
 fc⊥ = 237.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.38)   ➜  OK
9/26/2022 6
