Size: 4 x 16
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Live Load: 256 plf
Dead Load: 64 plf
Selfweight: 246.3 lbs
Dist. Selfweight: 12.47 plf
Total Weight: 249.4 lbs
Beam Design 2022A643
9/26/2022 1
d = 15.000 in.
9/26/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (237.00 + 3)] x (12 in./ft.)3 = 7.29 ft3
Volumespan = N[A x L] = 1 x [52.50 x 237.00] x (12 in./ft.)3 = 7.20 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 7.29 = 249.4 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 7.20 = 246.3 lbs
256 plf
64 plf
ws = 12.47 plf
19.75 ft.
19.50 ft.
3324.70 lbs
3324.70 lbs
9/26/2022 3
lu/d = = 1.60
Rb = = 7.78
 Rb = 7.78 < 50   ➜  OK
9/26/2022 4
FbE = = 11496.76 psi
CL =   = 0.996
Fbx' = (900)(1.00)(1)(1)(0.996)(1)(1)(1) = 896.2 psi
fb = = 1482.1 psi
 fb = 1482.1 psi > Fbx' = 896.2 psi  (CSI = 1.65)   ➜  NG
fv* = = 81.93 psi
 fv* = 81.93 psi < Fvx' = 180.00 psi  (CSI = 0.46)   ➜  OK
fv = = 93.80 psi
 fv = 93.80 psi < Fvx' = 180.00 psi  (CSI = 0.52)   ➜  OK
9/26/2022 5
ΔLL = = 0.56 in.
(L/d)LL = 237.00 / 0.56 = 426
 ΔLL = 0.56 in = L/426 < L/360   ➜  OK
ΔTL = = 0.72 in.
(L/d)TL = 237.00 / 0.72 = 328
 ΔTL = 0.72 in = L/328 < L/240   ➜  OK
fc⊥ = = 316.6 psi
 fc⊥ = 316.6 psi < Fc⊥x' = 625.00 psi  (CSI = 0.51)   ➜  OK
9/26/2022 6
