Grade: SPF SS
Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 650 plf
Dead Load: 195 plf
Selfweight: 82.0 lbs
Dist. Selfweight: 8.41 plf
Total Weight: 84.1 lbs
Beam Design 2022A640
9/26/2022 1
9/26/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (117.00 + 3)] x (12 in./ft.)3 = 2.89 ft3
Volumespan = N[A x L] = 3 x [13.88 x 117.00] x (12 in./ft.)3 = 2.82 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.89 = 84.1 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.82 = 82.0 lbs
Distributed Self Weight (ws) = = 8.41 plf
650 plf
195 plf
ws = 8.41 plf
9.75 ft.
9.50 ft.
10.00 ft.
4267.06 lbs
4267.06 lbs
9/26/2022 3
Fbx' = (1250)(1.15)(1)(1)(1)(1.1)(1)(1) = 1581.3 psi
fb = = 1896.3 psi
 fb = 1896.3 psi > Fbx' = 1581.3 psi  (CSI = 1.20)   ➜  NG
9/26/2022 4
fv* = = 126.22 psi
 fv* = 126.22 psi < Fvx' = 155.25 psi  (CSI = 0.81)   ➜  OK
fv = = 149.92 psi
 fv = 149.92 psi < Fvx' = 155.25 psi  (CSI = 0.97)   ➜  OK
9/26/2022 5
ΔLL = = 0.30 in.
(L/d)LL = 117.00 / 0.30 = 394
 ΔLL = 0.30 in = L/394 < L/360   ➜  OK
ΔTL = = 0.39 in.
(L/d)TL = 117.00 / 0.39 = 300
 ΔTL = 0.39 in = L/300 < L/240   ➜  OK
fc⊥ = = 316.1 psi
 fc⊥ = 316.1 psi < Fc⊥x' = 425.00 psi  (CSI = 0.74)   ➜  OK
9/26/2022 6
