Grade: 24F-E4 1.8E DF/DF
Size: 3.5 x 15
Design Span (L): 20.25 ft.
Clear Span: 20.00 ft.
Total Span: 20.50 ft.
Live Load: 170 plf
Dead Load: 130 plf
Selfweight: 249.3 lbs
Dist. Selfweight: 12.31 plf
Total Weight: 252.3 lbs
Defl. Limits: 720|480
Beam Design 2022A64
2/5/2022 1
d = 15.000 in.
24F-E4 1.8E DF/DF 2400 1450 650 265 1800000 950000 1400 560 230 1700000 900000 1100 1700 0.5
Beam Design 2022A64
2/5/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (243.00 + 3)] x (12 in./ft.)3 = 7.47 ft3
Volumespan = N[A x L] = 1 x [52.50 x 243.00] x (12 in./ft.)3 = 7.38 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 7.47 = 252.3 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 7.38 = 249.3 lbs
170 plf
130 plf
  ws = 12.31 plf
20.25 ft.
20.50 ft.
3201.16 lbs
3201.16 lbs
Beam Design 2022A64
2/5/2022 3
fb = = 1463.6 psi
 fb = 1463.6 psi < Fbx' = 2760.0 psi  (CSI = 0.53)   ➜  OK
Beam Design 2022A64
2/5/2022 4
fv* = = 79.19 psi
 fv* = 79.19 psi < Fvx' = 304.75 psi  (CSI = 0.26)   ➜  OK
fv = = 90.35 psi
 fv = 90.35 psi < Fvx' = 304.75 psi  (CSI = 0.30)   ➜  OK
LL Allowable: L/720
TL Allowable: L/480
Beam Design 2022A64
2/5/2022 5
ΔLL = = 0.36 in.
(L/d)LL = 243.00 / 0.36 = 669
 ΔLL = 0.36 in = L/669 > L/720   ➜  NG
ΔTL = = 0.67 in.
(L/d)TL = 243.00 / 0.67 = 364
 ΔTL = 0.67 in = L/364 > L/480   ➜  NG
fc⊥ = = 304.9 psi
 fc⊥ = 304.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.47)   ➜  OK
Beam Design 2022A64
2/5/2022 6
