Grade: SP No.1
Design Span (L): 16.25 ft.
Clear Span: 16.00 ft.
Total Span: 16.50 ft.
Quantity (N): 4
Live Load: 529.6 plf
Dead Load: 118.4 plf
Selfweight: 284.3 lbs
Dist. Selfweight: 17.50 plf
Total Weight: 288.7 lbs
Beam Design Hunt Club 2022A634
9/21/2022 1
9/21/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (195.00 + 3)] x (12 in./ft.)3 = 7.73 ft3
Volumespan = N[A x L] = 4 x [16.88 x 195.00] x (12 in./ft.)3 = 7.62 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 7.73 = 288.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 7.62 = 284.3 lbs
Distributed Self Weight (ws) = = 17.50 plf
529.6 plf
118.4 plf
ws = 17.50 plf
16.25 ft.
16.50 ft.
5490.36 lbs
5490.36 lbs
9/21/2022 3
fb = = 2082.8 psi
 fb = 2082.8 psi > Fbx' = 1150.0 psi  (CSI = 1.81)   ➜  NG
9/21/2022 4
fv* = = 106.29 psi
 fv* = 106.29 psi < Fvx' = 201.25 psi  (CSI = 0.53)   ➜  OK
fv = = 120.16 psi
 fv = 120.16 psi < Fvx' = 201.25 psi  (CSI = 0.60)   ➜  OK
9/21/2022 5
ΔLL = = 0.73 in.
(L/d)LL = 195.00 / 0.73 = 267
 ΔLL = 0.73 in = L/267 < L/240   ➜  OK
ΔTL = = 0.92 in.
(L/d)TL = 195.00 / 0.92 = 213
 ΔTL = 0.92 in = L/213 < L/180   ➜  OK
fc⊥ = = 305.0 psi
 fc⊥ = 305.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.54)   ➜  OK
9/21/2022 6
