Design Span (L): 5.75 ft.
Clear Span: 5.50 ft.
Total Span: 6.00 ft.
Live Load: 270 plf
Dead Load: 52 plf
Selfweight: 62.0 lbs
Dist. Selfweight: 10.79 plf
Total Weight: 64.7 lbs
Beam Design Campbell 2022A632
9/20/2022 1
9/20/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (69.00 + 3)] x (12 in./ft.)3 = 1.73 ft3
Volumespan = N[A x L] = 3 x [13.88 x 69.00] x (12 in./ft.)3 = 1.66 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.73 = 64.7 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.66 = 62.0 lbs
Distributed Self Weight (ws) = = 10.79 plf
270 plf
52 plf
ws = 10.79 plf
5.75 ft.
5.50 ft.
998.37 lbs
998.37 lbs
9/20/2022 3
fb = = 257.2 psi
 fb = 257.2 psi < Fbx' = 920.0 psi  (CSI = 0.28)   ➜  OK
9/20/2022 4
fv* = = 25.23 psi
 fv* = 25.23 psi < Fvx' = 201.25 psi  (CSI = 0.13)   ➜  OK
fv = = 34.48 psi
 fv = 34.48 psi < Fvx' = 201.25 psi  (CSI = 0.17)   ➜  OK
9/20/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 69.00 / 0.02 = 4317
 ΔLL = 0.02 in = L/4317 < L/360   ➜  OK
ΔTL = = 0.02 in.
(L/d)TL = 69.00 / 0.02 = 3503
 ΔTL = 0.02 in = L/3503 < L/240   ➜  OK
fc⊥ = = 74.0 psi
 fc⊥ = 74.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.13)   ➜  OK
9/20/2022 6
