Size: 3.125 x 21
Design Span (L): 11.54 ft.
Clear Span: 11.08 ft.
Bearing (lb): 5.5 in.
Live Load: 1726 plf
Dead Load: 244 plf
Selfweight: 177.6 lbs
Dist. Selfweight: 15.39 plf
Total Weight: 184.6 lbs
Beam Design 2022A628
9/16/2022 1
b = 3.125 in.
d = 21.000 in.
A = 3.125 x 21.000 = 65.63 in.2
Sx = (3.125)(21.000)2/6 = 229.69 in.3
Sy = (3.125)2(21.000)/6 = 34.18 in.3
Ix = (3.125)(21.000)3/12 = 2411.72 in.4
Iy = (3.125)3(21.000)/12 = 53.41 in.4
9/16/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [65.63 x (138.50 + 5.5)] x (12 in./ft.)3 = 5.47 ft3
Volumespan = N[A x L] = 1 x [65.63 x 138.50] x (12 in./ft.)3 = 5.26 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.47 = 184.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.26 = 177.6 lbs
Distributed Self Weight (ws) = = 15.39 plf
1726 plf
244 plf
  ws = 15.39 plf
11.54 ft.
11.08 ft.
11912.65 lbs
11912.65 lbs
9/16/2022 3
fb = = 1727.3 psi
 fb = 1727.3 psi < Fbx' = 2760.0 psi  (CSI = 0.63)   ➜  OK
9/16/2022 4
fv* = = 182.47 psi
 fv* = 182.47 psi < Fvx' = 304.75 psi  (CSI = 0.60)   ➜  OK
fv = = 261.89 psi
 fv = 261.89 psi < Fvx' = 304.75 psi  (CSI = 0.86)   ➜  OK
9/16/2022 5
ΔLL = = 0.16 in.
(L/d)LL = 138.50 / 0.16 = 872
 ΔLL = 0.16 in = L/872 < L/360   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 138.50 / 0.18 = 758
 ΔTL = 0.18 in = L/758 < L/240   ➜  OK
Ab = b x lb = 3.125 x 5.5 = 17.19 in2
fc⊥ = = 693.1 psi
 fc⊥ = 693.1 psi > Fc⊥x' = 650.00 psi  (CSI = 1.07)   ➜  NG
9/16/2022 6
