Design Span (L): 7.09 ft.
Clear Span: 6.67 ft.
Total Span: 7.50 ft.
Bearing (lb): 5 in.
Selfweight: 54.9 lbs
Dist. Selfweight: 7.75 plf
Total Weight: 58.1 lbs
Beam Design 2022A625
9/8/2022 1
9/8/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (85.04 + 5)] x (12 in./ft.)3 = 1.70 ft3
Volumespan = N[A x L] = 3 x [10.88 x 85.04] x (12 in./ft.)3 = 1.61 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.70 = 58.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.61 = 54.9 lbs
Distributed Self Weight (ws) = = 7.75 plf
ws = 7.75 plf
7.09 ft.
6.67 ft.
7.50 ft.
685.64 lbs
685.64 lbs
9/8/2022 3
fb = = 349.2 psi
 fb = 349.2 psi < Fbx' = 1242.0 psi  (CSI = 0.28)   ➜  OK
9/8/2022 4
fv* = = 24.70 psi
 fv* = 24.70 psi < Fvx' = 207.00 psi  (CSI = 0.12)   ➜  OK
fv = = 29.77 psi
 fv = 29.77 psi < Fvx' = 207.00 psi  (CSI = 0.14)   ➜  OK
9/8/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 85.04 / 0.02 = 3426
 ΔLL = 0.02 in = L/3426 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 85.04 / 0.05 = 1875
 ΔTL = 0.05 in = L/1875 < L/240   ➜  OK
Ab = b x lb = 1.5 x 5 = 7.50 in2
fc⊥ = = 30.5 psi
 fc⊥ = 30.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.05)   ➜  OK
9/8/2022 6
