Design Span (L): 14.75 ft.
Clear Span: 14.50 ft.
Total Span: 15.00 ft.
Selfweight: 76.2 lbs
Dist. Selfweight: 5.17 plf
Total Weight: 77.5 lbs
Orientation: Horizontal
Beam Design 2022A623
9/7/2022 1
9/7/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [10.88 x (177.00 + 3)] x (12 in./ft.)3 = 2.27 ft3
Volumespan = N[A x L] = 2 x [10.88 x 177.00] x (12 in./ft.)3 = 2.23 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.27 = 77.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.23 = 76.2 lbs
ws = 5.17 plf
14.75 ft.
14.50 ft.
15.00 ft.
1351.25 lbs
1351.25 lbs
9/7/2022 3
Fby' = (900)(1.15)(1)(1)(1)(1.2)(1.15)(1)(1) = 1428.3 psi
fb = = 10813.1 psi
 fb = 10813.1 psi > Fby' = 1428.3 psi  (CSI = 7.57)   ➜  NG
9/7/2022 4
fv* = = 90.08 psi
 fv* = 90.08 psi < Fvy' = 207.00 psi  (CSI = 0.44)   ➜  OK
fv = = 91.64 psi
 fv = 91.64 psi < Fvy' = 207.00 psi  (CSI = 0.44)   ➜  OK
9/7/2022 5
ΔLL = = 16.32 in.
(L/d)LL = 177.00 / 16.32 = 11
 ΔLL = 16.32 in = L/11 > L/360   ➜  NG
ΔTL = = 29.41 in.
(L/d)TL = 177.00 / 29.41 = 6
 ΔTL = 29.41 in = L/6 > L/240   ➜  NG
Ab = d x lb = 7.25 x 3 = 21.75 in2
fc⊥ = = 31.1 psi
 fc⊥ = 31.1 psi < Fc⊥y' = 625.00 psi  (CSI = 0.05)   ➜  OK
9/7/2022 6
