Grade: DF No.1
Size: 4 x 16
Design Span (L): 23.25 ft.
Clear Span: 23.00 ft.
Total Span: 23.50 ft.
Live Load: 484 plf
Dead Load: 388 plf
Selfweight: 300.6 lbs
Dist. Selfweight: 12.93 plf
Total Weight: 303.9 lbs
Beam Design 2022A622
9/6/2022 1
d = 15.000 in.
9/6/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [52.50 x (279.00 + 3)] x (12 in./ft.)3 = 8.57 ft3
Volumespan = N[A x L] = 1 x [52.50 x 279.00] x (12 in./ft.)3 = 8.48 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 8.57 = 303.9 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 8.48 = 300.6 lbs
Distributed Self Weight (ws) = = 12.93 plf
484 plf
388 plf
ws = 12.93 plf
23.25 ft.
23.00 ft.
23.50 ft.
10397.94 lbs
10397.94 lbs
9/6/2022 3
Fbx' = (1000)(1.00)(1)(1)(1)(1)(1)(1.15) = 1150.0 psi
fb = = 5467.0 psi
 fb = 5467.0 psi > Fbx' = 1150.0 psi  (CSI = 4.75)   ➜  NG
9/6/2022 4
Fvx' = (180)(1.00)(0.97)(1)(1) = 174.60 psi
fv* = = 262.32 psi
 fv* = 262.32 psi > Fvx' = 174.60 psi  (CSI = 1.50)   ➜  NG
fv = = 293.92 psi
 fv = 293.92 psi > Fvx' = 174.60 psi  (CSI = 1.68)   ➜  NG
Ex' = Ex(CM)(Ct)(Ci) = 1700000(0.9)(1)(1) = 1530000 psi
9/6/2022 5
ΔLL = = 2.11 in.
(L/d)LL = 279.00 / 2.11 = 132
 ΔLL = 2.11 in = L/132 > L/360   ➜  NG
ΔTL = = 3.86 in.
(L/d)TL = 279.00 / 3.86 = 72
 ΔTL = 3.86 in = L/72 > L/240   ➜  NG
fc⊥ = = 990.3 psi
 fc⊥ = 990.3 psi > Fc⊥x' = 418.75 psi  (CSI = 2.36)   ➜  NG
9/6/2022 6
