Grade: 24F-V3 1.8E SP/SP
Size: 5 x 16.5
Design Span (L): 20.25 ft.
Clear Span: 20.00 ft.
Total Span: 20.50 ft.
Selfweight: 428.0 lbs
Dist. Selfweight: 21.13 plf
Total Weight: 433.3 lbs
CV Volume Factor 0.987b - - - - -
Beam Design 2022A621
9/6/2022 1
b = 5.000 in.
d = 16.500 in.
A = 5.000 x 16.500 = 82.50 in.2
Sx = (5.000)(16.500)2/6 = 226.88 in.3
Sy = (5.000)2(16.500)/6 = 68.75 in.3
Ix = (5.000)(16.500)3/12 = 1871.72 in.4
Iy = (5.000)3(16.500)/12 = 171.88 in.4
9/6/2022 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [82.50 x (243.00 + 3)] x (12 in./ft.)3 = 11.74 ft3
Volumespan = N[A x L] = 1 x [82.50 x 243.00] x (12 in./ft.)3 = 11.60 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 11.74 = 433.3 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 11.60 = 428.0 lbs
Distributed Self Weight (ws) = = 21.13 plf
  ws = 21.13 plf
20.25 ft.
20.50 ft.
2010.38 lbs
2010.38 lbs
9/6/2022 3
CV = = 0.987
CV = 0.987 < CL = 1
Fbx' = (2400)(1.15)(1)(1)(0.987) = 2724.7 psi
fb = = 531.8 psi
 fb = 531.8 psi < Fbx' = 2724.7 psi  (CSI = 0.20)   ➜  OK
9/6/2022 4
fv* = = 31.20 psi
 fv* = 31.20 psi < Fvx' = 345.00 psi  (CSI = 0.09)   ➜  OK
fv = = 36.11 psi
 fv = 36.11 psi < Fvx' = 345.00 psi  (CSI = 0.10)   ➜  OK
9/6/2022 5
ΔLL = = 0.11 in.
(L/d)LL = 243.00 / 0.11 = 2164
 ΔLL = 0.11 in = L/2164 < L/360   ➜  OK
ΔTL = = 0.22 in.
(L/d)TL = 243.00 / 0.22 = 1103
 ΔTL = 0.22 in = L/1103 < L/240   ➜  OK
Ab = b x lb = 5 x 3 = 15.00 in2
fc⊥ = = 134.0 psi
 fc⊥ = 134.0 psi < Fc⊥x' = 740.00 psi  (CSI = 0.18)   ➜  OK
9/6/2022 6
