Size: 3.5 x 12
Design Span (L): 20.25 ft.
Clear Span: 20.00 ft.
Total Span: 20.50 ft.
Selfweight: 199.4 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 201.9 lbs
Beam Design 2022A62
2/5/2022 1
Beam Design 2022A62
2/5/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (243.00 + 3)] x (12 in./ft.)3 = 5.98 ft3
Volumespan = N[A x L] = 1 x [42.00 x 243.00] x (12 in./ft.)3 = 5.91 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.98 = 201.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.91 = 199.4 lbs
  ws = 9.85 plf
20.25 ft.
20.50 ft.
1894.68 lbs
1894.68 lbs
Beam Design 2022A62
2/5/2022 3
fb = = 1353.6 psi
 fb = 1353.6 psi < Fbx' = 2760.0 psi  (CSI = 0.49)   ➜  OK
Beam Design 2022A62
2/5/2022 4
fv* = = 60.24 psi
 fv* = 60.24 psi < Fvx' = 304.75 psi  (CSI = 0.20)   ➜  OK
fv = = 66.84 psi
 fv = 66.84 psi < Fvx' = 304.75 psi  (CSI = 0.22)   ➜  OK
Beam Design 2022A62
2/5/2022 5
ΔLL = = 0.42 in.
(L/d)LL = 243.00 / 0.42 = 583
 ΔLL = 0.42 in = L/583 < L/360   ➜  OK
ΔTL = = 0.77 in.
(L/d)TL = 243.00 / 0.77 = 315
 ΔTL = 0.77 in = L/315 < L/240   ➜  OK
fc⊥ = = 180.4 psi
 fc⊥ = 180.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.28)   ➜  OK
Beam Design 2022A62
2/5/2022 6
