Grade: SP No.1
Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 557 plf
Dead Load: 93.6 plf
Selfweight: 67.8 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 70.0 lbs
Beam Design 1589 Stanley Ct 2022A617
9/1/2022 1
9/1/2022 2
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.88 = 70.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.82 = 67.8 lbs
557 plf
93.6 plf
ws = 8.75 plf
7.75 ft.
7.50 ft.
2637.40 lbs
2637.40 lbs
9/1/2022 3
fb = = 938.7 psi
 fb = 938.7 psi < Fbx' = 1150.0 psi  (CSI = 0.82)   ➜  OK
9/1/2022 4
fv* = = 86.08 psi
 fv* = 86.08 psi < Fvx' = 201.25 psi  (CSI = 0.43)   ➜  OK
fv = = 113.55 psi
 fv = 113.55 psi < Fvx' = 201.25 psi  (CSI = 0.56)   ➜  OK
9/1/2022 5
ΔLL = = 0.08 in.
(L/d)LL = 93.00 / 0.08 = 1172
 ΔLL = 0.08 in = L/1172 < L/180   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 93.00 / 0.09 = 990
 ΔTL = 0.09 in = L/990 < L/120   ➜  OK
fc⊥ = = 293.0 psi
 fc⊥ = 293.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.52)   ➜  OK
9/1/2022 6
