Beam Design - 90-92 MATHER STREET
Selfweight: 47.1 lbs
Dist. Selfweight: 4.01 plf
Total Weight: 48.1 lbs
Beam Design 90-92 MATHER STREET, HARTFORD CT 2022-004.000
8/16/2022 1
8/16/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (141.00 + 3)] x (12 in./ft.)3 = 1.41 ft3
Volumespan = N[A x L] = 1 x [16.88 x 141.00] x (12 in./ft.)3 = 1.38 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.41 = 48.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.38 = 47.1 lbs
ws = 4.01 plf
1074.05 lbs
1074.05 lbs
8/16/2022 3
Fbx' = (900)(1.15)(1)(1)(1)(1)(1)(1.15) = 1190.3 psi
fb = = 1171.6 psi
 fb = 1171.6 psi < Fbx' = 1190.3 psi  (CSI = 0.98)   ➜  OK
8/16/2022 4
fv* = = 78.56 psi
 fv* = 78.56 psi < Fvx' = 207.00 psi  (CSI = 0.38)   ➜  OK
fv = = 93.48 psi
 fv = 93.48 psi < Fvx' = 207.00 psi  (CSI = 0.45)   ➜  OK
8/16/2022 5
ΔLL = = 0.15 in.
(L/d)LL = 141.00 / 0.15 = 936
 ΔLL = 0.15 in = L/936 < L/360   ➜  OK
ΔTL = = 0.27 in.
(L/d)TL = 141.00 / 0.27 = 523
 ΔTL = 0.27 in = L/523 < L/240   ➜  OK
fc⊥ = = 238.7 psi
 fc⊥ = 238.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.38)   ➜  OK
8/16/2022 6
