Design Span (L): 11.88 ft.
Clear Span: 11.75 ft.
Bearing (lb): 1.5 in.
Live Load: 22 plf
Dead Load: 40 plf
Selfweight: 46.5 lbs
Dist. Selfweight: 3.92 plf
Total Weight: 47.0 lbs
Beam Design 2022A606
8/13/2022 1
8/13/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [8.25 x (142.50 + 1.5)] x (12 in./ft.)3 = 1.38 ft3
Volumespan = N[A x L] = 2 x [8.25 x 142.50] x (12 in./ft.)3 = 1.36 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.38 = 47.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.36 = 46.5 lbs
22 plf
40 plf
ws = 3.92 plf
11.88 ft.
395.51 lbs
395.51 lbs
8/13/2022 3
fb = = 921.9 psi
 fb = 921.9 psi < Fbx' = 1170.0 psi  (CSI = 0.79)   ➜  OK
8/13/2022 4
fv* = = 32.83 psi
 fv* = 32.83 psi < Fvx' = 180.00 psi  (CSI = 0.18)   ➜  OK
fv = = 35.58 psi
 fv = 35.58 psi < Fvx' = 180.00 psi  (CSI = 0.20)   ➜  OK
8/13/2022 5
ΔLL = = 0.15 in.
(L/d)LL = 142.50 / 0.15 = 963
 ΔLL = 0.15 in = L/963 < L/360   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 142.50 / 0.44 = 322
 ΔTL = 0.44 in = L/322 < L/240   ➜  OK
fc⊥ = = 87.9 psi
 fc⊥ = 87.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.14)   ➜  OK
8/13/2022 6
