Grade: 24F-V3 1.8E SP/SP
Size: 3.125 x 15.125
Design Span (L): 19.25 ft.
Clear Span: 19.00 ft.
Total Span: 19.50 ft.
Live Load: 20 plf
Dead Load: 10 plf
Selfweight: 233.1 lbs
Dist. Selfweight: 12.11 plf
Total Weight: 236.1 lbs
Beam Design 2022A605
8/12/2022 1
b = 3.125 in.
d = 15.125 in.
A = 3.125 x 15.125 = 47.27 in.2
Sx = (3.125)(15.125)2/6 = 119.15 in.3
Sy = (3.125)2(15.125)/6 = 24.62 in.3
Ix = (3.125)(15.125)3/12 = 901.06 in.4
Iy = (3.125)3(15.125)/12 = 38.46 in.4
8/12/2022 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [47.27 x (231.00 + 3)] x (12 in./ft.)3 = 6.40 ft3
Volumespan = N[A x L] = 1 x [47.27 x 231.00] x (12 in./ft.)3 = 6.32 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 6.40 = 236.1 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 6.32 = 233.1 lbs
Distributed Self Weight (ws) = = 12.11 plf
20 plf
10 plf
  ws = 12.11 plf
19.25 ft.
19.00 ft.
19.50 ft.
410.56 lbs
410.56 lbs
8/12/2022 3
fb = = 196.4 psi
 fb = 196.4 psi < Fbx' = 2400.0 psi  (CSI = 0.08)   ➜  OK
8/12/2022 4
fv* = = 11.18 psi
 fv* = 11.18 psi < Fvx' = 300.00 psi  (CSI = 0.04)   ➜  OK
fv = = 12.86 psi
 fv = 12.86 psi < Fvx' = 300.00 psi  (CSI = 0.04)   ➜  OK
8/12/2022 5
ΔLL = = 0.04 in.
(L/d)LL = 231.00 / 0.04 = 6063
 ΔLL = 0.04 in = L/6063 < L/360   ➜  OK
ΔTL = = 0.08 in.
(L/d)TL = 231.00 / 0.08 = 2880
 ΔTL = 0.08 in = L/2880 < L/240   ➜  OK
fc⊥ = = 43.8 psi
 fc⊥ = 43.8 psi < Fc⊥x' = 740.00 psi  (CSI = 0.06)   ➜  OK
8/12/2022 6
