Beam Design - Glulam Beam Calculation
Size: 3.125 x 12
Design Span (L): 20.25 ft.
Clear Span: 20.00 ft.
Total Span: 20.50 ft.
Live Load: 200 plf
Dead Load: 150 plf
Selfweight: 178.0 lbs
Dist. Selfweight: 8.79 plf
Total Weight: 180.2 lbs
Load Duration: 1.60
Orientation: Horizontal
Cfu Flat Use Factor 1.161c - - - - -
Beam Design BJ Ma For 4307 Shamrock, CV 4307
8/11/2022 1
b = 3.125 in.
8/11/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [37.50 x (243.00 + 3)] x (12 in./ft.)3 = 5.34 ft3
Volumespan = N[A x L] = 1 x [37.50 x 243.00] x (12 in./ft.)3 = 5.27 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.34 = 180.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.27 = 178.0 lbs
200 plf
150 plf
  ws = 8.79 plf
20.25 ft.
20.50 ft.
3677.62 lbs
3677.62 lbs
8/11/2022 3
Cfu = = 1.161
Fby' = (1450)(1.60)(1)(1)(1)(1.161) = 2694.1 psi
fb = = 11299.4 psi
 fb = 11299.4 psi > Fby' = 2694.1 psi  (CSI = 4.19)   ➜  NG
8/11/2022 4
Fvy' = (230)(1.60)(1)(1) = 424.00 psi
fv* = = 141.57 psi
 fv* = 141.57 psi < Fvy' = 368.00 psi  (CSI = 0.38)   ➜  OK
fv = = 145.31 psi
 fv = 145.31 psi < Fvy' = 368.00 psi  (CSI = 0.39)   ➜  OK
Ey' = Ey(CM)(Ct) = 1600000(1)(1) = 1600000 psi
8/11/2022 5
ΔLL = = 15.50 in.
(L/d)LL = 243.00 / 15.50 = 16
 ΔLL = 15.50 in = L/16 > L/360   ➜  NG
ΔTL = = 27.80 in.
(L/d)TL = 243.00 / 27.80 = 9
 ΔTL = 27.80 in = L/9 > L/240   ➜  NG
Fc⊥y' = (560)(1)(1) = 560.00 psi
Ab = d x lb = 12 x 3 = 36.00 in2
fc⊥ = = 102.2 psi
 fc⊥ = 102.2 psi < Fc⊥y' = 560.00 psi  (CSI = 0.18)   ➜  OK
8/11/2022 6
