Size: 5.125 x 13.5
Design Span (L): 11.38 ft.
Clear Span: 11.00 ft.
Total Span: 11.75 ft.
Bearing (lb): 4.5 in.
Live Load: 1121.0 plf
Dead Load: 570. plf
Selfweight: 184.5 lbs
Dist. Selfweight: 16.22 plf
Total Weight: 190.6 lbs
Beam Design 2022A60
2/4/2022 1
b = 5.125 in.
d = 13.500 in.
A = 5.125 x 13.500 = 69.19 in.2
Sx = (5.125)(13.500)2/6 = 155.67 in.3
Sy = (5.125)2(13.500)/6 = 59.10 in.3
Ix = (5.125)(13.500)3/12 = 1050.79 in.4
Iy = (5.125)3(13.500)/12 = 151.44 in.4
Beam Design 2022A60
2/4/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [69.19 x (136.50 + 4.5)] x (12 in./ft.)3 = 5.65 ft3
Volumespan = N[A x L] = 1 x [69.19 x 136.50] x (12 in./ft.)3 = 5.47 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.65 = 190.6 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.47 = 184.5 lbs
Distributed Self Weight (ws) = = 16.22 plf
1121.0 plf
570. plf
  ws = 16.22 plf
11.38 ft.
11.00 ft.
10029.92 lbs
10029.92 lbs
Beam Design 2022A60
2/4/2022 3
fb = = 2128.5 psi
 fb = 2128.5 psi < Fbx' = 2760.0 psi  (CSI = 0.77)   ➜  OK
Beam Design 2022A60
2/4/2022 4
fv* = = 168.87 psi
 fv* = 168.87 psi < Fvx' = 304.75 psi  (CSI = 0.55)   ➜  OK
fv = = 210.51 psi
 fv = 210.51 psi < Fvx' = 304.75 psi  (CSI = 0.69)   ➜  OK
Beam Design 2022A60
2/4/2022 5
ΔLL = = 0.22 in.
(L/d)LL = 136.50 / 0.22 = 611
 ΔLL = 0.22 in = L/611 < L/180   ➜  OK
ΔTL = = 0.34 in.
(L/d)TL = 136.50 / 0.34 = 401
 ΔTL = 0.34 in = L/401 < L/120   ➜  OK
Ab = b x lb = 5.125 x 4.5 = 23.06 in2
fc⊥ = = 434.9 psi
 fc⊥ = 434.9 psi < Fc⊥x' = 650.00 psi  (CSI = 0.67)   ➜  OK
Beam Design 2022A60
2/4/2022 6
