Beam Design - The Beam
Size: 3.5 x 12
Selfweight: 115.7 lbs
Dist. Selfweight: 9.85 plf
Total Weight: 118.2 lbs
Beam Design B.J. Ma 453 Dutches Lane , Hayward 3231
8/10/2022 1
8/10/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (141.00 + 3)] x (12 in./ft.)3 = 3.50 ft3
Volumespan = N[A x L] = 1 x [42.00 x 141.00] x (12 in./ft.)3 = 3.43 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 3.50 = 118.2 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 3.43 = 115.7 lbs
  ws = 9.85 plf
1109.08 lbs
1109.08 lbs
8/10/2022 3
fb = = 455.7 psi
 fb = 455.7 psi < Fbx' = 2760.0 psi  (CSI = 0.17)   ➜  OK
8/10/2022 4
fv* = = 32.18 psi
 fv* = 32.18 psi < Fvx' = 304.75 psi  (CSI = 0.11)   ➜  OK
fv = = 38.78 psi
 fv = 38.78 psi < Fvx' = 304.75 psi  (CSI = 0.13)   ➜  OK
8/10/2022 5
ΔLL = = 0.05 in.
(L/d)LL = 141.00 / 0.05 = 2983
 ΔLL = 0.05 in = L/2983 < L/360   ➜  OK
ΔTL = = 0.09 in.
(L/d)TL = 141.00 / 0.09 = 1614
 ΔTL = 0.09 in = L/1614 < L/240   ➜  OK
fc⊥ = = 105.6 psi
 fc⊥ = 105.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.16)   ➜  OK
8/10/2022 6
