Grade: DF SS
Size: 4 x 12
Design Span (L): 10.25 ft.
Clear Span: 9.75 ft.
Total Span: 10.75 ft.
Selfweight: 95.9 lbs
Dist. Selfweight: 9.35 plf
Total Weight: 100.5 lbs
CF Size Factor 1.1 1 - 1 - -
Beam Design 2022A592
8/9/2022 1
8/9/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [39.38 x (123.00 + 6)] x (12 in./ft.)3 = 2.94 ft3
Volumespan = N[A x L] = 1 x [39.38 x 123.00] x (12 in./ft.)3 = 2.80 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.94 = 100.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.80 = 95.9 lbs
ws = 9.35 plf
10.25 ft.
9.75 ft.
10.75 ft.
990.89 lbs
990.89 lbs
8/9/2022 3
Fbx' = (1500)(1.15)(1)(1)(1)(1.1)(1)(1) = 1897.5 psi
fb = = 393.5 psi
 fb = 393.5 psi < Fbx' = 1897.5 psi  (CSI = 0.21)   ➜  OK
8/9/2022 4
fv* = = 29.41 psi
 fv* = 29.41 psi < Fvx' = 207.00 psi  (CSI = 0.14)   ➜  OK
fv = = 35.99 psi
 fv = 35.99 psi < Fvx' = 207.00 psi  (CSI = 0.17)   ➜  OK
8/9/2022 5
ΔLL = = 0.03 in.
(L/d)LL = 123.00 / 0.03 = 3908
 ΔLL = 0.03 in = L/3908 < L/360   ➜  OK
ΔTL = = 0.06 in.
(L/d)TL = 123.00 / 0.06 = 2120
 ΔTL = 0.06 in = L/2120 < L/240   ➜  OK
fc⊥ = = 47.2 psi
 fc⊥ = 47.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.08)   ➜  OK
8/9/2022 6
