Beam Design - IMTEC
Grade: DF No.1
Size: 2 x 4
Design Span (L): 7.83 ft.
Clear Span: 7.67 ft.
Total Span: 8.00 ft.
Bearing (lb): 2 in.
Live Load: 240 lbs
Dead Load: lbs
Selfweight: 9.8 lbs
Dist. Selfweight: 1.25 plf
Total Weight: 10.0 lbs
Load Duration: 1.33
Beam Design Amir Zamani 21R-140
8/8/2022 1
d = 3.500 in.
A = 1.500 x 3.500 = 5.25 in.2
8/8/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [5.25 x (94.00 + 2)] x (12 in./ft.)3 = 0.29 ft3
Volumespan = N[A x L] = 1 x [5.25 x 94.00] x (12 in./ft.)3 = 0.29 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.29 = 10.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.29 = 9.8 lbs
Distributed Self Weight (ws) = = 1.25 plf
240 lbs
lbs
ws = 1.25 plf
7.83 ft.
7.67 ft.
124.99 lbs
124.99 lbs
8/8/2022 3
Fbx' = (1000)(1.33)(1)(1)(1)(1.5)(1)(1) = 1995.0 psi
fb = = 1879.0 psi
 fb = 1879.0 psi < Fbx' = 1995.0 psi  (CSI = 0.94)   ➜  OK
8/8/2022 4
Fvx' = (180)(1.33)(1)(1)(1) = 239.40 psi
fv* = = 35.58 psi
 fv* = 35.58 psi < Fvx' = 239.40 psi  (CSI = 0.15)   ➜  OK
fv = = 35.68 psi
 fv = 35.68 psi < Fvx' = 239.40 psi  (CSI = 0.15)   ➜  OK
8/8/2022 5
ΔLL =   =   = 0.46 in.
(L/d)LL = 94.00 / 0.46 = 206
 ΔLL = 0.46 in = L/206 < L/180   ➜  OK
ΔTL =   =   = 0.47 in.
(L/d)TL = 94.00 / 0.47 = 201
 ΔTL = 0.47 in = L/201 < L/120   ➜  OK
fc⊥ = = 41.7 psi
 fc⊥ = 41.7 psi < Fc⊥x' = 625.00 psi  (CSI = 0.07)   ➜  OK
8/8/2022 6
