Species: Hem-Fir
Grade: HF No.2
Size: 4 x 6
Design Span (L): 3.57 ft.
Clear Span: 3.28 ft.
Total Span: 3.86 ft.
Bearing (lb): 3.5 in.
Live Load: 530 plf
Dead Load: 320 plf
Selfweight: 14.2 lbs
Dist. Selfweight: 3.98 plf
Total Weight: 15.3 lbs
Incised Lumber: Yes
Beam Design 2022A588
8/8/2022 1
G = 0.43
8/8/2022 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (42.82 + 3.5)] x (12 in./ft.)3 = 0.52 ft3
Volumespan = N[A x L] = 1 x [19.25 x 42.82] x (12 in./ft.)3 = 0.48 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 0.52 = 15.3 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 0.48 = 14.2 lbs
Distributed Self Weight (ws) = = 3.98 plf
530 plf
320 plf
ws = 3.98 plf
3.57 ft.
3.28 ft.
3.86 ft.
1648.03 lbs
1648.03 lbs
8/8/2022 3
Fbx' = (850)(1.15)(1)(1)(1)(1.3)(0.8)(1) = 1016.6 psi
fb = = 924.2 psi
 fb = 924.2 psi < Fbx' = 1016.6 psi  (CSI = 0.91)   ➜  OK
8/8/2022 4
Fvx' = (150)(1.15)(1)(1)(0.8) = 138.00 psi
fv* = = 88.21 psi
 fv* = 88.21 psi < Fvx' = 138.00 psi  (CSI = 0.64)   ➜  OK
fv = = 118.71 psi
 fv = 118.71 psi < Fvx' = 138.00 psi  (CSI = 0.86)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(1)(1)(0.95) = 1235000 psi
8/8/2022 5
ΔLL = = 0.03 in.
(L/d)LL = 42.82 / 0.03 = 1328
 ΔLL = 0.03 in = L/1328 < L/180   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 42.82 / 0.05 = 824
 ΔTL = 0.05 in = L/824 < L/120   ➜  OK
fc⊥ = = 134.5 psi
 fc⊥ = 134.5 psi < Fc⊥x' = 405.00 psi  (CSI = 0.33)   ➜  OK
8/8/2022 6
