Grade: SPF No.2
Design Span (L): 12.00 ft.
Clear Span: 11.75 ft.
Total Span: 12.25 ft.
Live Load: 420 plf
Dead Load: 20 plf
Selfweight: 81.8 lbs
Dist. Selfweight: 6.82 plf
Total Weight: 83.5 lbs
Beam Design 2022A582
8/1/2022 1
8/1/2022 2
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (144.00 + 3)] x (12 in./ft.)3 = 2.87 ft3
Volumespan = N[A x L] = 2 x [16.88 x 144.00] x (12 in./ft.)3 = 2.81 ft3
Total Weight (WT) = ρw x Volumetotal = 29.10 x 2.87 = 83.5 lbs
Self Weight (WS) = ρw x Volumespan = 29.10 x 2.81 = 81.8 lbs
420 plf
20 plf
ws = 6.82 plf
12.25 ft.
2736.77 lbs
2736.77 lbs
8/1/2022 3
fb = = 1525.1 psi
 fb = 1525.1 psi > Fbx' = 1006.2 psi  (CSI = 1.52)   ➜  NG
8/1/2022 4
fv* = = 100.53 psi
 fv* = 100.53 psi < Fvx' = 155.25 psi  (CSI = 0.65)   ➜  OK
fv = = 119.15 psi
 fv = 119.15 psi < Fvx' = 155.25 psi  (CSI = 0.77)   ➜  OK
8/1/2022 5
ΔLL = = 0.39 in.
(L/d)LL = 144.00 / 0.39 = 366
 ΔLL = 0.39 in = L/366 < L/360   ➜  OK
ΔTL = = 0.42 in.
(L/d)TL = 144.00 / 0.42 = 344
 ΔTL = 0.42 in = L/344 < L/240   ➜  OK
fc⊥ = = 304.1 psi
 fc⊥ = 304.1 psi < Fc⊥x' = 425.00 psi  (CSI = 0.72)   ➜  OK
8/1/2022 6
