Grade: DF No.1 & Btr
Size: 4 x 10
Design Span (L): 15.33 ft.
Clear Span: 14.67 ft.
Total Span: 16.00 ft.
Bearing (lb): 8 in.
Live Load: 40 plf
Dead Load: 10 plf
Selfweight: 117.9 lbs
Dist. Selfweight: 7.69 plf
Total Weight: 123.0 lbs
Load Duration: 1.33
Orientation: Horizontal
Beam Design 2022A581
8/1/2022 1
8/1/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (184.00 + 8)] x (12 in./ft.)3 = 3.60 ft3
Volumespan = N[A x L] = 1 x [32.38 x 184.00] x (12 in./ft.)3 = 3.45 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 3.60 = 123.0 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 3.45 = 117.9 lbs
40 plf
10 plf
ws = 7.69 plf
15.33 ft.
14.67 ft.
461.51 lbs
461.51 lbs
8/1/2022 3
Fby' = (1200)(1.33)(1)(1)(1)(1.2)(1.1)(1)(1) = 2106.7 psi
fb = = 1077.3 psi
 fb = 1077.3 psi < Fby' = 2106.7 psi  (CSI = 0.51)   ➜  OK
8/1/2022 4
Fvy' = (180)(1.33)(1)(1)(1) = 239.40 psi
fv* = = 19.71 psi
 fv* = 19.71 psi < Fvy' = 239.40 psi  (CSI = 0.08)   ➜  OK
fv = = 20.49 psi
 fv = 20.49 psi < Fvy' = 239.40 psi  (CSI = 0.09)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1800000(1)(1)(1) = 1800000 psi
8/1/2022 5
ΔLL = = 0.84 in.
(L/d)LL = 184.00 / 0.84 = 220
 ΔLL = 0.84 in = L/220 > L/360   ➜  NG
ΔTL = = 1.21 in.
(L/d)TL = 184.00 / 1.21 = 153
 ΔTL = 1.21 in = L/153 > L/240   ➜  NG
Ab = d x lb = 9.25 x 8 = 74.00 in2
fc⊥ = = 6.2 psi
 fc⊥ = 6.2 psi < Fc⊥y' = 625.00 psi  (CSI = 0.01)   ➜  OK
8/1/2022 6
