Size: 5.125 x 12
Design Span (L): 12.50 ft.
Clear Span: 12.00 ft.
Total Span: 13.00 ft.
Live Load: 420 plf
Dead Load: 420 plf
Selfweight: 180.2 lbs
Dist. Selfweight: 14.42 plf
Total Weight: 187.4 lbs
Beam Design 2022A58
2/3/2022 1
b = 5.125 in.
Beam Design 2022A58
2/3/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [61.50 x (150.00 + 6)] x (12 in./ft.)3 = 5.55 ft3
Volumespan = N[A x L] = 1 x [61.50 x 150.00] x (12 in./ft.)3 = 5.34 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.55 = 187.4 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.34 = 180.2 lbs
420 plf
420 plf
  ws = 14.42 plf
12.50 ft.
13.00 ft.
5553.72 lbs
5553.72 lbs
Beam Design 2022A58
2/3/2022 3
fb = = 1628.1 psi
 fb = 1628.1 psi < Fbx' = 2760.0 psi  (CSI = 0.59)   ➜  OK
Beam Design 2022A58
2/3/2022 4
fv* = = 109.41 psi
 fv* = 109.41 psi < Fvx' = 304.75 psi  (CSI = 0.36)   ➜  OK
fv = = 130.25 psi
 fv = 130.25 psi < Fvx' = 304.75 psi  (CSI = 0.43)   ➜  OK
Beam Design 2022A58
2/3/2022 5
ΔLL = = 0.17 in.
(L/d)LL = 150.00 / 0.17 = 864
 ΔLL = 0.17 in = L/864 < L/360   ➜  OK
ΔTL = = 0.35 in.
(L/d)TL = 150.00 / 0.35 = 425
 ΔTL = 0.35 in = L/425 < L/240   ➜  OK
Ab = b x lb = 5.125 x 6 = 30.75 in2
fc⊥ = = 180.6 psi
 fc⊥ = 180.6 psi < Fc⊥x' = 650.00 psi  (CSI = 0.28)   ➜  OK
Beam Design 2022A58
2/3/2022 6
