Size: 4 x 6
Design Span (L): 3.67 ft.
Clear Span: 3.42 ft.
Total Span: 3.92 ft.
Live Load: 475 plf
Dead Load: 250 plf
Selfweight: 16.8 lbs
Dist. Selfweight: 4.57 plf
Total Weight: 17.9 lbs
Incised Lumber: Yes
Beam Design 2022A579
7/30/2022 1
7/30/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [19.25 x (44.04 + 3)] x (12 in./ft.)3 = 0.52 ft3
Volumespan = N[A x L] = 1 x [19.25 x 44.04] x (12 in./ft.)3 = 0.49 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.52 = 17.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.49 = 16.8 lbs
475 plf
250 plf
ws = 4.57 plf
3.67 ft.
3.42 ft.
3.92 ft.
1429.96 lbs
1429.96 lbs
7/30/2022 3
Fbx' = (900)(1.15)(1)(1)(1)(1.3)(0.8)(1) = 1076.4 psi
fb = = 835.3 psi
 fb = 835.3 psi < Fbx' = 1076.4 psi  (CSI = 0.78)   ➜  OK
7/30/2022 4
Fvx' = (180)(1.15)(1)(1)(0.8) = 165.60 psi
fv* = = 78.26 psi
 fv* = 78.26 psi < Fvx' = 165.60 psi  (CSI = 0.47)   ➜  OK
fv = = 104.32 psi
 fv = 104.32 psi < Fvx' = 165.60 psi  (CSI = 0.63)   ➜  OK
7/30/2022 5
ΔLL = = 0.03 in.
(L/d)LL = 44.04 / 0.03 = 1675
 ΔLL = 0.03 in = L/1675 < L/360   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 44.04 / 0.04 = 1091
 ΔTL = 0.04 in = L/1091 < L/240   ➜  OK
fc⊥ = = 136.2 psi
 fc⊥ = 136.2 psi < Fc⊥x' = 625.00 psi  (CSI = 0.22)   ➜  OK
7/30/2022 6
