Beam Design - Basement beams
Design Span (L): 11.50 ft.
Clear Span: 11.25 ft.
Total Span: 11.75 ft.
Dead Load: 10 plf
Selfweight: 50.3 lbs
Dist. Selfweight: 4.37 plf
Total Weight: 51.4 lbs
Beam Design Kemkem Cafe
7/29/2022 1
7/29/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [16.88 x (138.00 + 3)] x (12 in./ft.)3 = 1.38 ft3
Volumespan = N[A x L] = 1 x [16.88 x 138.00] x (12 in./ft.)3 = 1.35 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.38 = 51.4 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.35 = 50.3 lbs
10 plf
ws = 4.37 plf
11.25 ft.
671.95 lbs
671.95 lbs
7/29/2022 3
Fbx' = (750)(1.00)(1)(1)(1)(1)(1)(1) = 750.0 psi
fb = = 717.1 psi
 fb = 717.1 psi < Fbx' = 750.0 psi  (CSI = 0.96)   ➜  OK
7/29/2022 4
fv* = = 48.93 psi
 fv* = 48.93 psi < Fvx' = 175.00 psi  (CSI = 0.28)   ➜  OK
fv = = 58.46 psi
 fv = 58.46 psi < Fvx' = 175.00 psi  (CSI = 0.33)   ➜  OK
7/29/2022 5
ΔLL = = 0.16 in.
(L/d)LL = 138.00 / 0.16 = 874
 ΔLL = 0.16 in = L/874 < L/360   ➜  OK
ΔTL = = 0.18 in.
(L/d)TL = 138.00 / 0.18 = 764
 ΔTL = 0.18 in = L/764 < L/240   ➜  OK
fc⊥ = = 149.3 psi
 fc⊥ = 149.3 psi < Fc⊥x' = 565.00 psi  (CSI = 0.26)   ➜  OK
7/29/2022 6
