Size: 5.125 x 12
Design Span (L): 13.58 ft.
Clear Span: 13.17 ft.
Total Span: 14.00 ft.
Bearing (lb): 5 in.
Live Load: 744 plf
Dead Load: 180 plf
Selfweight: 195.9 lbs
Dist. Selfweight: 14.42 plf
Total Weight: 201.9 lbs
Beam Design 2022A576
7/29/2022 1
b = 5.125 in.
7/29/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [61.50 x (163.00 + 5)] x (12 in./ft.)3 = 5.98 ft3
Volumespan = N[A x L] = 1 x [61.50 x 163.00] x (12 in./ft.)3 = 5.80 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 5.98 = 201.9 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 5.80 = 195.9 lbs
744 plf
180 plf
  ws = 14.42 plf
13.58 ft.
13.17 ft.
6568.78 lbs
6568.78 lbs
7/29/2022 3
fb = = 2111.4 psi
 fb = 2111.4 psi < Fbx' = 2760.0 psi  (CSI = 0.77)   ➜  OK
7/29/2022 4
fv* = = 132.56 psi
 fv* = 132.56 psi < Fvx' = 304.75 psi  (CSI = 0.43)   ➜  OK
fv = = 155.45 psi
 fv = 155.45 psi < Fvx' = 304.75 psi  (CSI = 0.51)   ➜  OK
7/29/2022 5
ΔLL = = 0.43 in.
(L/d)LL = 163.00 / 0.43 = 380
 ΔLL = 0.43 in = L/380 < L/360   ➜  OK
ΔTL = = 0.54 in.
(L/d)TL = 163.00 / 0.54 = 301
 ΔTL = 0.54 in = L/301 < L/240   ➜  OK
Ab = b x lb = 5.125 x 5 = 25.63 in2
fc⊥ = = 256.3 psi
 fc⊥ = 256.3 psi < Fc⊥x' = 650.00 psi  (CSI = 0.39)   ➜  OK
7/29/2022 6
