Beam Design - Res Collins-Drake
Grade: 24F-V5 1.7E DF/HF
Size: 5.125 x 12
Design Span (L): 19.97 ft.
Clear Span: 19.63 ft.
Total Span: 20.30 ft.
Bearing (lb): 4 in.
Live Load: 82 plf
Dead Load: 165 plf
Selfweight: 287.9 lbs
Dist. Selfweight: 14.42 plf
Total Weight: 292.7 lbs
Beam Design 2022/39
7/29/2022 1
b = 5.125 in.
24F-V5 1.7E DF/HF 2400 1600 650 215 1700000 900000 1350 375 200 1500000 790000 1100 1450 0.5
Beam Design 2022/39
7/29/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [61.50 x (239.60 + 4)] x (12 in./ft.)3 = 8.67 ft3
Volumespan = N[A x L] = 1 x [61.50 x 239.60] x (12 in./ft.)3 = 8.53 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 8.67 = 292.7 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 8.53 = 287.9 lbs
82 plf
165 plf
  ws = 14.42 plf
19.97 ft.
19.63 ft.
20.30 ft.
2653.44 lbs
2653.44 lbs
Beam Design 2022/39
7/29/2022 3
fb = = 1271.0 psi
 fb = 1271.0 psi < Fbx' = 2400.0 psi  (CSI = 0.53)   ➜  OK
Beam Design 2022/39
7/29/2022 4
Fvx' = (215)(1.00)(1)(1) = 215.00 psi
fv* = = 57.28 psi
 fv* = 57.28 psi < Fvx' = 215.00 psi  (CSI = 0.27)   ➜  OK
fv = = 63.66 psi
 fv = 63.66 psi < Fvx' = 215.00 psi  (CSI = 0.30)   ➜  OK
Ex' = Ex(CM)(Ct) = 1700000(1)(1) = 1700000 psi
Beam Design 2022/39
7/29/2022 5
ΔLL = = 0.23 in.
(L/d)LL = 239.60 / 0.23 = 1025
 ΔLL = 0.23 in = L/1025 < L/180   ➜  OK
ΔTL = = 0.75 in.
(L/d)TL = 239.60 / 0.75 = 322
 ΔTL = 0.75 in = L/322 < L/120   ➜  OK
Ab = b x lb = 5.125 x 4 = 20.50 in2
fc⊥ = = 129.4 psi
 fc⊥ = 129.4 psi < Fc⊥x' = 650.00 psi  (CSI = 0.20)   ➜  OK
Beam Design 2022/39
7/29/2022 6
