Beam Design - Taylor Remodel
Size: 3.125 x 9
Design Span (L): 10.75 ft.
Clear Span: 10.50 ft.
Total Span: 11.00 ft.
Selfweight: 70.9 lbs
Dist. Selfweight: 6.59 plf
Total Weight: 72.5 lbs
CL Beam Stability Factor 0.941 - - - - -
Beam Design Bud Taylor White Sulphur Springs, MT 2022A570
7/28/2022 1
b = 3.125 in.
d = 9.000 in.
A = 3.125 x 9.000 = 28.13 in.2
Sx = (3.125)(9.000)2/6 = 42.19 in.3
Sy = (3.125)2(9.000)/6 = 14.65 in.3
Ix = (3.125)(9.000)3/12 = 189.84 in.4
Iy = (3.125)3(9.000)/12 = 22.89 in.4
7/28/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [28.13 x (129.00 + 3)] x (12 in./ft.)3 = 2.15 ft3
Volumespan = N[A x L] = 1 x [28.13 x 129.00] x (12 in./ft.)3 = 2.10 ft3
Total Weight (WT) = ρw x Volumetotal = 33.76 x 2.15 = 72.5 lbs
Self Weight (WS) = ρw x Volumespan = 33.76 x 2.10 = 70.9 lbs
  ws = 6.59 plf
10.75 ft.
10.50 ft.
11.00 ft.
998.77 lbs
998.77 lbs
7/28/2022 3
lu = Unbraced Length = 10.750 ft.
lu/d = = 14.33
le = 1.63lu + 3d = 1.63(129.0) + 3(9) = 237.27 in. = 19.77 ft.  (NDS Table 3.3.3)
Rb = = 14.79
 Rb = 14.79 < 50   ➜  OK
7/28/2022 4
FbE = = 4664.61 psi
CL =   = 0.941
CL = 0.941 < CV = 1.0
Fbx' = (2400)(1.15)(1)(1)(0.941) = 2596.9 psi
fb = = 746.1 psi
 fb = 746.1 psi < Fbx' = 2596.9 psi  (CSI = 0.29)   ➜  OK
fv* = = 44.79 psi
7/28/2022 5
 fv* = 44.79 psi < Fvx' = 304.75 psi  (CSI = 0.15)   ➜  OK
fv = = 52.06 psi
 fv = 52.06 psi < Fvx' = 304.75 psi  (CSI = 0.17)   ➜  OK
ΔLL = = 0.09 in.
(L/d)LL = 129.00 / 0.09 = 1467
 ΔLL = 0.09 in = L/1467 < L/360   ➜  OK
ΔTL = = 0.16 in.
(L/d)TL = 129.00 / 0.16 = 808
 ΔTL = 0.16 in = L/808 < L/240   ➜  OK
7/28/2022 6
fc⊥ = = 106.5 psi
 fc⊥ = 106.5 psi < Fc⊥x' = 650.00 psi  (CSI = 0.16)   ➜  OK
7/28/2022 7
