Design Span (L): 8.30 ft.
Clear Span: 8.05 ft.
Total Span: 8.55 ft.
Live Load: 520 plf
Dead Load: 195 plf
Selfweight: 82.1 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 84.5 lbs
Incised Lumber: Yes
Beam Design 2022A561
7/27/2022 1
7/27/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (99.60 + 3)] x (12 in./ft.)3 = 2.47 ft3
Volumespan = N[A x L] = 3 x [13.88 x 99.60] x (12 in./ft.)3 = 2.40 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.47 = 84.5 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.40 = 82.1 lbs
520 plf
195 plf
ws = 9.89 plf
8.30 ft.
8.05 ft.
8.55 ft.
3098.89 lbs
3098.89 lbs
7/27/2022 3
lu = Unbraced Length = 8.3 ft.
lu/d = = 10.77
le = 1.63lu + 3d = 1.63(99.6) + 3(9.25) = 190.10 in. = 15.84 ft.  (NDS Table 3.3.3)
Rb = = 9.32
 Rb = 9.32 < 50   ➜  OK
7/27/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(1)(1)(0.95) = 551000 psi
FbE = = 7614.45 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.1)(0.8)(1) = 910.80 psi
CL =   = 0.993
Fbx' = (900)(1.15)(1)(1)(0.993)(1.1)(0.8)(1) = 904.7 psi
fb = = 1167.3 psi
 fb = 1167.3 psi > Fbx' = 904.7 psi  (CSI = 1.29)   ➜  NG
Fvx' = (180)(1.15)(1)(1)(0.8) = 165.60 psi
fv* = = 88.27 psi
 fv* = 88.27 psi < Fvx' = 165.60 psi  (CSI = 0.53)   ➜  OK
fv = = 108.41 psi
 fv = 108.41 psi < Fvx' = 165.60 psi  (CSI = 0.65)   ➜  OK
7/27/2022 5
ΔLL = = 0.12 in.
(L/d)LL = 99.60 / 0.12 = 809
 ΔLL = 0.12 in = L/809 < L/360   ➜  OK
ΔTL = = 0.17 in.
(L/d)TL = 99.60 / 0.17 = 580
 ΔTL = 0.17 in = L/580 < L/240   ➜  OK
fc⊥ = = 229.5 psi
 fc⊥ = 229.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.37)   ➜  OK
7/27/2022 6
