Grade: 24F-V3 1.8E SP/SP
Size: 3.125 x 11
Design Span (L): 19.75 ft.
Clear Span: 19.50 ft.
Total Span: 20.00 ft.
Selfweight: 173.9 lbs
Dist. Selfweight: 8.81 plf
Total Weight: 176.1 lbs
Orientation: Horizontal
Cfu Flat Use Factor 1.161c - - - - -
Beam Design 2022A56
1/30/2022 1
b = 3.125 in.
d = 11.000 in.
A = 3.125 x 11.000 = 34.38 in.2
Sx = (3.125)(11.000)2/6 = 63.02 in.3
Sy = (3.125)2(11.000)/6 = 17.90 in.3
Ix = (3.125)(11.000)3/12 = 346.61 in.4
Iy = (3.125)3(11.000)/12 = 27.97 in.4
Beam Design 2022A56
1/30/2022 2
= 36.89 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [34.38 x (237.00 + 3)] x (12 in./ft.)3 = 4.77 ft3
Volumespan = N[A x L] = 1 x [34.38 x 237.00] x (12 in./ft.)3 = 4.71 ft3
Total Weight (WT) = ρw x Volumetotal = 36.89 x 4.77 = 176.1 lbs
Self Weight (WS) = ρw x Volumespan = 36.89 x 4.71 = 173.9 lbs
Distributed Self Weight (ws) = = 8.81 plf
  ws = 8.81 plf
19.75 ft.
19.50 ft.
1838.06 lbs
1838.06 lbs
Beam Design 2022A56
1/30/2022 3
Cfu = = 1.161
Fby' = (1700)(1.15)(1)(1)(1)(1.161) = 2270.2 psi
fb = = 6006.8 psi
 fb = 6006.8 psi > Fby' = 2270.2 psi  (CSI = 2.65)   ➜  NG
Beam Design 2022A56
1/30/2022 4
Fvy' = (260)(1.15)(1)(1) = 345.00 psi
fv* = = 77.12 psi
 fv* = 77.12 psi < Fvy' = 299.00 psi  (CSI = 0.26)   ➜  OK
fv = = 79.20 psi
 fv = 79.20 psi < Fvy' = 299.00 psi  (CSI = 0.26)   ➜  OK
Ey' = Ey(CM)(Ct) = 1600000(1)(1) = 1600000 psi
Beam Design 2022A56
1/30/2022 5
ΔLL = = 7.65 in.
(L/d)LL = 237.00 / 7.65 = 31
 ΔLL = 7.65 in = L/31 > L/180   ➜  NG
ΔTL = = 14.06 in.
(L/d)TL = 237.00 / 14.06 = 17
 ΔTL = 14.06 in = L/17 > L/120   ➜  NG
Fc⊥y' = (650)(1)(1) = 650.00 psi
Ab = d x lb = 11 x 3 = 33.00 in2
fc⊥ = = 55.7 psi
 fc⊥ = 55.7 psi < Fc⊥y' = 650.00 psi  (CSI = 0.09)   ➜  OK
Beam Design 2022A56
1/30/2022 6
