Design Span (L): 8.30 ft.
Clear Span: 8.05 ft.
Total Span: 8.55 ft.
Live Load: 520 plf
Dead Load: 195 plf
Selfweight: 64.3 lbs
Dist. Selfweight: 7.75 plf
Total Weight: 66.3 lbs
Incised Lumber: Yes
Beam Design 2022A559
7/27/2022 1
7/27/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [10.88 x (99.60 + 3)] x (12 in./ft.)3 = 1.94 ft3
Volumespan = N[A x L] = 3 x [10.88 x 99.60] x (12 in./ft.)3 = 1.88 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 1.94 = 66.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 1.88 = 64.3 lbs
Distributed Self Weight (ws) = = 7.75 plf
520 plf
195 plf
ws = 7.75 plf
8.30 ft.
8.05 ft.
8.55 ft.
3089.75 lbs
3089.75 lbs
7/27/2022 3
lu = Unbraced Length = 8.3 ft.
lu/d = = 13.74
le = 1.63lu + 3d = 1.63(99.6) + 3(7.25) = 184.10 in. = 15.34 ft.  (NDS Table 3.3.3)
Rb = = 8.12
 Rb = 8.12 < 50   ➜  OK
7/27/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 580000(1)(1)(0.95) = 551000 psi
FbE = = 10031.61 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (900)(1.15)(1)(1)(1.2)(0.8)(1) = 993.60 psi
CL =   = 0.995
Fbx' = (900)(1.15)(1)(1)(0.995)(1.2)(0.8)(1) = 988.2 psi
fb = = 1894.5 psi
 fb = 1894.5 psi > Fbx' = 988.2 psi  (CSI = 1.92)   ➜  NG
Fvx' = (180)(1.15)(1)(1)(0.8) = 165.60 psi
fv* = = 117.83 psi
 fv* = 117.83 psi < Fvx' = 165.60 psi  (CSI = 0.71)   ➜  OK
fv = = 137.90 psi
 fv = 137.90 psi < Fvx' = 165.60 psi  (CSI = 0.83)   ➜  OK
7/27/2022 5
ΔLL = = 0.26 in.
(L/d)LL = 99.60 / 0.26 = 390
 ΔLL = 0.26 in = L/390 < L/360   ➜  OK
ΔTL = = 0.36 in.
(L/d)TL = 99.60 / 0.36 = 280
 ΔTL = 0.36 in = L/280 < L/240   ➜  OK
fc⊥ = = 228.9 psi
 fc⊥ = 228.9 psi < Fc⊥x' = 625.00 psi  (CSI = 0.37)   ➜  OK
7/27/2022 6
