Design Span (L): 15.89 ft.
Clear Span: 15.78 ft.
Total Span: 16.00 ft.
Bearing (lb): 1.33 in.
Live Load: 75 plf
Selfweight: 208.5 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 210.0 lbs
Load Duration: 1.33
Beam Design 2022A553
7/25/2022 1
7/25/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (190.67 + 1.33)] x (12 in./ft.)3 = 5.62 ft3
Volumespan = N[A x L] = 3 x [16.88 x 190.67] x (12 in./ft.)3 = 5.59 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 5.62 = 210.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 5.59 = 208.5 lbs
ws = 13.12 plf
15.89 ft.
15.78 ft.
1304.98 lbs
1304.98 lbs
7/25/2022 3
Fbx' = (750)(1.33)(1)(0.8)(1)(1)(1)(1) = 798.0 psi
fb = = 650.8 psi
 fb = 650.8 psi < Fbx' = 798.0 psi  (CSI = 0.82)   ➜  OK
7/25/2022 4
Fvx' = (175)(1.33)(1)(0.8)(1) = 186.20 psi
fv* = = 33.87 psi
 fv* = 33.87 psi < Fvx' = 186.20 psi  (CSI = 0.18)   ➜  OK
fv = = 38.40 psi
 fv = 38.40 psi < Fvx' = 186.20 psi  (CSI = 0.21)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1400000(1)(0.9)(1) = 1260000 psi
7/25/2022 5
ΔLL = = 0.16 in.
(L/d)LL = 190.67 / 0.16 = 1193
 ΔLL = 0.16 in = L/1193 < L/360   ➜  OK
ΔTL = = 0.35 in.
(L/d)TL = 190.67 / 0.35 = 548
 ΔTL = 0.35 in = L/548 < L/240   ➜  OK
Fc⊥x' = (565)(1)(0.8)(1) = 452.00 psi
Ab = b x lb = 1.5 x 1.33 = 2.00 in2
fc⊥ = = 218.0 psi
 fc⊥ = 218.0 psi < Fc⊥x' = 452.00 psi  (CSI = 0.48)   ➜  OK
7/25/2022 6
