Beam Design - 413 leppo deck
Design Span (L): 9.54 ft.
Clear Span: 9.08 ft.
Total Span: 10.00 ft.
Bearing (lb): 5.5 in.
Selfweight: 125.2 lbs
Dist. Selfweight: 13.12 plf
Total Weight: 131.2 lbs
Beam Design Noah Matesa 2022A548
7/22/2022 1
7/22/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (114.50 + 5.5)] x (12 in./ft.)3 = 3.52 ft3
Volumespan = N[A x L] = 3 x [16.88 x 114.50] x (12 in./ft.)3 = 3.35 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 3.52 = 131.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 3.35 = 125.2 lbs
ws = 13.12 plf
9.54 ft.
9.08 ft.
10.00 ft.
940.65 lbs
940.65 lbs
7/22/2022 3
fb = = 270.7 psi
 fb = 270.7 psi < Fbx' = 862.5 psi  (CSI = 0.31)   ➜  OK
7/22/2022 4
fv* = = 21.37 psi
 fv* = 21.37 psi < Fvx' = 201.25 psi  (CSI = 0.11)   ➜  OK
fv = = 26.59 psi
 fv = 26.59 psi < Fvx' = 201.25 psi  (CSI = 0.13)   ➜  OK
7/22/2022 5
ΔLL = = 0.02 in.
(L/d)LL = 114.50 / 0.02 = 4589
 ΔLL = 0.02 in = L/4589 < L/180   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 114.50 / 0.05 = 2439
 ΔTL = 0.05 in = L/2439 < L/120   ➜  OK
fc⊥ = = 38.0 psi
 fc⊥ = 38.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.07)   ➜  OK
7/22/2022 6
