Beam Design - Coakley Deck Calc
Species: Hem-Fir
Grade: HF No.2
Size: 4 x 10
Design Span (L): 6.85 ft.
Clear Span: 6.71 ft.
Total Span: 7.00 ft.
Bearing (lb): 1.75 in.
Live Load: 60 plf
Dead Load: 10 plf
Selfweight: 45.8 lbs
Dist. Selfweight: 6.69 plf
Total Weight: 46.8 lbs
Incised Lumber: Yes
Beam Design Henri Weeks 170 Settlers Lane, Chehalis, WA 98532 1
7/21/2022 1
G = 0.43
7/21/2022 2
= 29.74 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [32.38 x (82.25 + 1.75)] x (12 in./ft.)3 = 1.57 ft3
Volumespan = N[A x L] = 1 x [32.38 x 82.25] x (12 in./ft.)3 = 1.54 ft3
Total Weight (WT) = ρw x Volumetotal = 29.74 x 1.57 = 46.8 lbs
Self Weight (WS) = ρw x Volumespan = 29.74 x 1.54 = 45.8 lbs
Distributed Self Weight (ws) = = 6.69 plf
60 plf
10 plf
ws = 6.69 plf
6.85 ft.
6.71 ft.
7.00 ft.
268.40 lbs
268.40 lbs
7/21/2022 3
Fbx' = (850)(1.15)(1)(1)(1)(1.2)(0.8)(1.15) = 1079.2 psi
fb = = 108.3 psi
 fb = 108.3 psi < Fbx' = 1079.2 psi  (CSI = 0.10)   ➜  OK
7/21/2022 4
Fvx' = (150)(1.15)(1)(1)(0.8) = 138.00 psi
fv* = = 9.44 psi
 fv* = 9.44 psi < Fvx' = 138.00 psi  (CSI = 0.07)   ➜  OK
fv = = 12.18 psi
 fv = 12.18 psi < Fvx' = 138.00 psi  (CSI = 0.09)   ➜  OK
Ex' = Ex(CM)(Ct)(Ci) = 1300000(1)(1)(0.95) = 1235000 psi
7/21/2022 5
ΔLL = = 0.01 in.
(L/d)LL = 82.25 / 0.01 = 7870
 ΔLL = 0.01 in = L/7870 < L/180   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 82.25 / 0.01 = 6158
 ΔTL = 0.01 in = L/6158 < L/120   ➜  OK
Ab = b x lb = 3.5 x 1.75 = 6.13 in2
fc⊥ = = 43.8 psi
 fc⊥ = 43.8 psi < Fc⊥x' = 405.00 psi  (CSI = 0.11)   ➜  OK
7/21/2022 6
