Design Span (L): 7.75 ft.
Clear Span: 7.50 ft.
Total Span: 8.00 ft.
Live Load: 30.8 plf
Dead Load: 50.5 plf
Selfweight: 67.8 lbs
Dist. Selfweight: 8.75 plf
Total Weight: 70.0 lbs
Beam Design 2100 James 2022A546
7/20/2022 1
7/20/2022 2
Total Weight (WT) = ρw x Volumetotal = 37.33 x 1.88 = 70.0 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 1.82 = 67.8 lbs
30.8 plf
50.5 plf
ws = 8.75 plf
7.75 ft.
7.50 ft.
360.20 lbs
360.20 lbs
7/20/2022 3
fb = = 128.2 psi
 fb = 128.2 psi < Fbx' = 862.5 psi  (CSI = 0.15)   ➜  OK
7/20/2022 4
fv* = = 11.76 psi
 fv* = 11.76 psi < Fvx' = 201.25 psi  (CSI = 0.06)   ➜  OK
fv = = 15.51 psi
 fv = 15.51 psi < Fvx' = 201.25 psi  (CSI = 0.08)   ➜  OK
7/20/2022 5
ΔLL = = 0.01 in.
(L/d)LL = 93.00 / 0.01 = 18538
 ΔLL = 0.01 in = L/18538 < L/180   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 93.00 / 0.01 = 6341
 ΔTL = 0.01 in = L/6341 < L/120   ➜  OK
fc⊥ = = 40.0 psi
 fc⊥ = 40.0 psi < Fc⊥x' = 565.00 psi  (CSI = 0.07)   ➜  OK
7/20/2022 6
