Design Span (L): 13.54 ft.
Clear Span: 13.08 ft.
Total Span: 14.00 ft.
Bearing (lb): 5.5 in.
Live Load: 235 plf
Dead Load: 110 plf
Selfweight: 162.8 lbs
Dist. Selfweight: 12.02 plf
Total Weight: 168.3 lbs
Beam Design 2022A545
7/20/2022 1
7/20/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [16.88 x (162.50 + 5.5)] x (12 in./ft.)3 = 4.92 ft3
Volumespan = N[A x L] = 3 x [16.88 x 162.50] x (12 in./ft.)3 = 4.76 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 4.92 = 168.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 4.76 = 162.8 lbs
235 plf
110 plf
ws = 12.02 plf
13.54 ft.
13.08 ft.
2499.23 lbs
2499.23 lbs
7/20/2022 3
fb = = 1034.6 psi
 fb = 1034.6 psi < Fbx' = 1035.0 psi  (CSI = 1.00)   ➜  OK
7/20/2022 4
fv* = = 61.71 psi
 fv* = 61.71 psi < Fvx' = 207.00 psi  (CSI = 0.30)   ➜  OK
fv = = 71.63 psi
 fv = 71.63 psi < Fvx' = 207.00 psi  (CSI = 0.35)   ➜  OK
7/20/2022 5
ΔLL = = 0.21 in.
(L/d)LL = 162.50 / 0.21 = 781
 ΔLL = 0.21 in = L/781 < L/240   ➜  OK
ΔTL = = 0.32 in.
(L/d)TL = 162.50 / 0.32 = 514
 ΔTL = 0.32 in = L/514 < L/180   ➜  OK
fc⊥ = = 101.0 psi
 fc⊥ = 101.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.16)   ➜  OK
7/20/2022 6
