Size: 4 x 4
Design Span (L): 1.05 ft.
Clear Span: 0.80 ft.
Total Span: 1.30 ft.
Live Load: 1485 lbs
Dead Load: 75 lbs
Selfweight: 3.1 lbs
Dist. Selfweight: 2.91 plf
Total Weight: 3.8 lbs
Beam Design John Howland LENDA
7/20/2022 1
d = 3.500 in.
7/20/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [12.25 x (12.60 + 3)] x (12 in./ft.)3 = 0.11 ft3
Volumespan = N[A x L] = 1 x [12.25 x 12.60] x (12 in./ft.)3 = 0.09 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.11 = 3.8 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.09 = 3.1 lbs
1485 lbs
75 lbs
ws = 2.91 plf
1.05 ft.
0.80 ft.
1.30 ft.
781.89 lbs
781.89 lbs
7/20/2022 3
Fbx' = (900)(1.15)(1)(1)(1)(1.5)(1)(1) = 1552.5 psi
fb = = 688.3 psi
 fb = 688.3 psi < Fbx' = 1552.5 psi  (CSI = 0.44)   ➜  OK
7/20/2022 4
fv* = = 95.59 psi
 fv* = 95.59 psi < Fvx' = 207.00 psi  (CSI = 0.46)   ➜  OK
fv = = 95.70 psi
 fv = 95.70 psi < Fvx' = 207.00 psi  (CSI = 0.46)   ➜  OK
7/20/2022 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 12.60 / 0.00 = 4074
 ΔLL = 0.00 in = L/4074 < L/360   ➜  OK
ΔTL =   =   = 0.00 in.
(L/d)TL = 12.60 / 0.00 = 3873
 ΔTL = 0.00 in = L/3873 < L/240   ➜  OK
fc⊥ = = 74.5 psi
 fc⊥ = 74.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.12)   ➜  OK
7/20/2022 6
