Design Span (L): 1.05 ft.
Clear Span: 0.80 ft.
Total Span: 1.30 ft.
Live Load: 1485 lbs
Dead Load: 75 lbs
Selfweight: 3.5 lbs
Dist. Selfweight: 3.30 plf
Total Weight: 4.3 lbs
Beam Design John Howland LENDA
7/20/2022 1
7/20/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (12.60 + 3)] x (12 in./ft.)3 = 0.13 ft3
Volumespan = N[A x L] = 1 x [13.88 x 12.60] x (12 in./ft.)3 = 0.10 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.13 = 4.3 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.10 = 3.5 lbs
1485 lbs
75 lbs
ws = 3.30 plf
1.05 ft.
0.80 ft.
1.30 ft.
782.14 lbs
782.14 lbs
7/20/2022 3
fb = = 230.0 psi
 fb = 230.0 psi < Fbx' = 1138.5 psi  (CSI = 0.20)   ➜  OK
7/20/2022 4
fv* = = 43.76 psi
 fv* = 43.76 psi < Fvx' = 207.00 psi  (CSI = 0.21)   ➜  OK
fv = = 84.51 psi
 fv = 84.51 psi < Fvx' = 207.00 psi  (CSI = 0.41)   ➜  OK
7/20/2022 5
ΔLL =   =   = 0.00 in.
(L/d)LL = 12.60 / 0.00 = 32228
 ΔLL = 0.00 in = L/32228 < L/360   ➜  OK
ΔTL =   =   = 0.00 in.
(L/d)TL = 12.60 / 0.00 = 30636
 ΔTL = 0.00 in = L/30636 < L/240   ➜  OK
fc⊥ = = 173.8 psi
 fc⊥ = 173.8 psi < Fc⊥x' = 625.00 psi  (CSI = 0.28)   ➜  OK
7/20/2022 6
