Design Span (L): 18.33 ft.
Clear Span: 17.33 ft.
Total Span: 19.33 ft.
Bearing (lb): 12 in.
Quantity (N): 4
Live Load: 155 plf
Dead Load: 10 plf
Selfweight: 320.7 lbs
Dist. Selfweight: 17.50 plf
Total Weight: 338.2 lbs
Beam Design 2022A54
1/29/2022 1
Beam Design 2022A54
1/29/2022 2
Volumetotal = N[A x (L + lb)] = 4 x [16.88 x (219.96 + 12)] x (12 in./ft.)3 = 9.06 ft3
Volumespan = N[A x L] = 4 x [16.88 x 219.96] x (12 in./ft.)3 = 8.59 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 9.06 = 338.2 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 8.59 = 320.7 lbs
Distributed Self Weight (ws) = = 17.50 plf
155 plf
10 plf
ws = 17.50 plf
18.33 ft.
17.33 ft.
19.33 ft.
1763.85 lbs
1763.85 lbs
Beam Design 2022A54
1/29/2022 3
Fbx' = (750)(1.00)(1)(1)(1)(1)(1)(1) = 750.0 psi
fb = = 726.7 psi
 fb = 726.7 psi < Fbx' = 750.0 psi  (CSI = 0.97)   ➜  OK
Beam Design 2022A54
1/29/2022 4
fv* = = 33.37 psi
 fv* = 33.37 psi < Fvx' = 175.00 psi  (CSI = 0.19)   ➜  OK
fv = = 37.17 psi
 fv = 37.17 psi < Fvx' = 175.00 psi  (CSI = 0.21)   ➜  OK
Beam Design 2022A54
1/29/2022 5
ΔLL = = 0.40 in.
(L/d)LL = 219.96 / 0.40 = 557
 ΔLL = 0.40 in = L/557 < L/180   ➜  OK
ΔTL = = 0.47 in.
(L/d)TL = 219.96 / 0.47 = 473
 ΔTL = 0.47 in = L/473 < L/120   ➜  OK
Ab = b x lb = 1.5 x 12 = 18.00 in2
fc⊥ = = 24.5 psi
 fc⊥ = 24.5 psi < Fc⊥x' = 565.00 psi  (CSI = 0.04)   ➜  OK
Beam Design 2022A54
1/29/2022 6
