Size: 3.5 x 12
Design Span (L): 15.75 ft.
Clear Span: 15.50 ft.
Total Span: 16.00 ft.
Live Load: 200 plf
Selfweight: 162.9 lbs
Dist. Selfweight: 10.34 plf
Total Weight: 165.5 lbs
CL Beam Stability Factor 0.901 - - - - -
Beam Design 2022A539
7/20/2022 1
7/20/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (189.00 + 3)] x (12 in./ft.)3 = 4.67 ft3
Volumespan = N[A x L] = 1 x [42.00 x 189.00] x (12 in./ft.)3 = 4.59 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 4.67 = 165.5 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 4.59 = 162.9 lbs
Distributed Self Weight (ws) = = 10.34 plf
200 plf
  ws = 10.34 plf
15.75 ft.
15.50 ft.
2282.76 lbs
2282.76 lbs
7/20/2022 3
lu = Unbraced Length = 15.750 ft.
lu/d = = 15.75
le = 1.63lu + 3d = 1.63(189.0) + 3(12) = 344.07 in. = 28.67 ft.  (NDS Table 3.3.3)
Rb = = 18.36
 Rb = 18.36 < 50   ➜  OK
7/20/2022 4
FbE = = 2520.89 psi
Fbx* = Fbx(CD)(CM)(Ct) = (2400)(1.00)(0.8)(1) = 1920.00 psi
CL =   = 0.901
CL = 0.901 < CV = 1.0
Fbx' = (2400)(1.00)(0.8)(1)(0.901) = 1730.5 psi
fb = = 1264.0 psi
 fb = 1264.0 psi < Fbx' = 1730.5 psi  (CSI = 0.73)   ➜  OK
Fvx' = (265)(1.00)(0.875)(1) = 231.88 psi
fv* = = 70.06 psi
7/20/2022 5
 fv* = 70.06 psi < Fvx' = 231.88 psi  (CSI = 0.30)   ➜  OK
fv = = 80.25 psi
 fv = 80.25 psi < Fvx' = 231.88 psi  (CSI = 0.35)   ➜  OK
ΔLL = = 0.37 in.
(L/d)LL = 189.00 / 0.37 = 516
 ΔLL = 0.37 in = L/516 < L/180   ➜  OK
ΔTL = = 0.52 in.
(L/d)TL = 189.00 / 0.52 = 362
 ΔTL = 0.52 in = L/362 < L/120   ➜  OK
7/20/2022 6
fc⊥ = = 217.4 psi
 fc⊥ = 217.4 psi < Fc⊥x' = 344.50 psi  (CSI = 0.63)   ➜  OK
7/20/2022 7
