Design Span (L): 6.75 ft.
Clear Span: 6.50 ft.
Total Span: 7.00 ft.
Live Load: 54 plf
Dead Load: 25 plf
Selfweight: 17.4 lbs
Dist. Selfweight: 2.58 plf
Total Weight: 18.1 lbs
Beam Design 2022A533
7/18/2022 1
7/18/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [10.88 x (81.00 + 3)] x (12 in./ft.)3 = 0.53 ft3
Volumespan = N[A x L] = 1 x [10.88 x 81.00] x (12 in./ft.)3 = 0.51 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 0.53 = 18.1 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 0.51 = 17.4 lbs
54 plf
25 plf
ws = 2.58 plf
6.75 ft.
6.50 ft.
7.00 ft.
285.54 lbs
285.54 lbs
7/18/2022 3
Fbx' = (900)(1.00)(1)(1)(1)(1.2)(1)(1.15) = 1242.0 psi
fb = = 424.3 psi
 fb = 424.3 psi < Fbx' = 1242.0 psi  (CSI = 0.34)   ➜  OK
7/18/2022 4
fv* = = 31.18 psi
 fv* = 31.18 psi < Fvx' = 180.00 psi  (CSI = 0.17)   ➜  OK
fv = = 37.98 psi
 fv = 37.98 psi < Fvx' = 180.00 psi  (CSI = 0.21)   ➜  OK
7/18/2022 5
ΔLL = = 0.03 in.
(L/d)LL = 81.00 / 0.03 = 2448
 ΔLL = 0.03 in = L/2448 < L/360   ➜  OK
ΔTL = = 0.05 in.
(L/d)TL = 81.00 / 0.05 = 1620
 ΔTL = 0.05 in = L/1620 < L/240   ➜  OK
fc⊥ = = 63.5 psi
 fc⊥ = 63.5 psi < Fc⊥x' = 625.00 psi  (CSI = 0.10)   ➜  OK
7/18/2022 6
