Design Span (L): 9.75 ft.
Clear Span: 9.50 ft.
Total Span: 10.00 ft.
Live Load: 210 plf
Dead Load: 223 plf
Selfweight: 96.4 lbs
Dist. Selfweight: 9.89 plf
Total Weight: 98.9 lbs
Beam Design 2022A531
7/18/2022 1
7/18/2022 2
Volumetotal = N[A x (L + lb)] = 3 x [13.88 x (117.00 + 3)] x (12 in./ft.)3 = 2.89 ft3
Volumespan = N[A x L] = 3 x [13.88 x 117.00] x (12 in./ft.)3 = 2.82 ft3
Total Weight (WT) = ρw x Volumetotal = 34.20 x 2.89 = 98.9 lbs
Self Weight (WS) = ρw x Volumespan = 34.20 x 2.82 = 96.4 lbs
210 plf
223 plf
ws = 9.89 plf
9.75 ft.
9.50 ft.
10.00 ft.
2214.43 lbs
2214.43 lbs
7/18/2022 3
fb = = 984.1 psi
 fb = 984.1 psi < Fbx' = 990.0 psi  (CSI = 0.99)   ➜  OK
7/18/2022 4
fv* = = 65.50 psi
 fv* = 65.50 psi < Fvx' = 180.00 psi  (CSI = 0.36)   ➜  OK
fv = = 77.80 psi
 fv = 77.80 psi < Fvx' = 180.00 psi  (CSI = 0.43)   ➜  OK
7/18/2022 5
ΔLL = = 0.09 in.
(L/d)LL = 117.00 / 0.09 = 1301
 ΔLL = 0.09 in = L/1301 < L/360   ➜  OK
ΔTL = = 0.19 in.
(L/d)TL = 117.00 / 0.19 = 617
 ΔTL = 0.19 in = L/617 < L/240   ➜  OK
fc⊥ = = 164.0 psi
 fc⊥ = 164.0 psi < Fc⊥x' = 625.00 psi  (CSI = 0.26)   ➜  OK
7/18/2022 6
