Size: 3.5 x 12
Design Span (L): 13.71 ft.
Clear Span: 13.42 ft.
Total Span: 14.00 ft.
Bearing (lb): 3.5 in.
Live Load: 410 plf
Dead Load: 0 plf
Selfweight: 141.8 lbs
Dist. Selfweight: 10.34 plf
Total Weight: 144.8 lbs
Beam Design 2022A524
7/14/2022 1
7/14/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [42.00 x (164.50 + 3.5)] x (12 in./ft.)3 = 4.08 ft3
Volumespan = N[A x L] = 1 x [42.00 x 164.50] x (12 in./ft.)3 = 4.00 ft3
Total Weight (WT) = ρw x Volumetotal = 35.47 x 4.08 = 144.8 lbs
Self Weight (WS) = ρw x Volumespan = 35.47 x 4.00 = 141.8 lbs
Distributed Self Weight (ws) = = 10.34 plf
410 plf
0 plf
  ws = 10.34 plf
13.71 ft.
13.42 ft.
2942.34 lbs
2942.34 lbs
7/14/2022 3
fb = = 1410.5 psi
 fb = 1410.5 psi < Fbx' = 2208.0 psi  (CSI = 0.64)   ➜  OK
7/14/2022 4
fv* = = 87.88 psi
 fv* = 87.88 psi < Fvx' = 266.66 psi  (CSI = 0.33)   ➜  OK
fv = = 102.89 psi
 fv = 102.89 psi < Fvx' = 266.66 psi  (CSI = 0.39)   ➜  OK
7/14/2022 5
ΔLL = = 0.43 in.
(L/d)LL = 164.50 / 0.43 = 382
 ΔLL = 0.43 in = L/382 < L/360   ➜  OK
ΔTL = = 0.44 in.
(L/d)TL = 164.50 / 0.44 = 372
 ΔTL = 0.44 in = L/372 < L/240   ➜  OK
fc⊥ = = 240.2 psi
 fc⊥ = 240.2 psi < Fc⊥x' = 344.50 psi  (CSI = 0.70)   ➜  OK
7/14/2022 6
