Design Span (L): 13.25 ft.
Clear Span: 13.00 ft.
Total Span: 13.50 ft.
Selfweight: 119.8 lbs
Dist. Selfweight: 9.04 plf
Total Weight: 122.1 lbs
Beam Design 2022A520
7/12/2022 1
7/12/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 2 x [16.88 x (159.00 + 3)] x (12 in./ft.)3 = 3.16 ft3
Volumespan = N[A x L] = 2 x [16.88 x 159.00] x (12 in./ft.)3 = 3.11 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 3.16 = 122.1 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 3.11 = 119.8 lbs
Distributed Self Weight (ws) = = 9.04 plf
ws = 9.04 plf
13.25 ft.
13.00 ft.
13.50 ft.
1242.29 lbs
1242.29 lbs
7/12/2022 3
fb = = 765.9 psi
 fb = 765.9 psi < Fbx' = 862.5 psi  (CSI = 0.89)   ➜  OK
7/12/2022 4
fv* = = 46.52 psi
 fv* = 46.52 psi < Fvx' = 195.21 psi  (CSI = 0.24)   ➜  OK
fv = = 54.19 psi
 fv = 54.19 psi < Fvx' = 195.21 psi  (CSI = 0.28)   ➜  OK
7/12/2022 5
ΔLL = = 0.15 in.
(L/d)LL = 159.00 / 0.15 = 1028
 ΔLL = 0.15 in = L/1028 < L/360   ➜  OK
ΔTL = = 0.28 in.
(L/d)TL = 159.00 / 0.28 = 559
 ΔTL = 0.28 in = L/559 < L/240   ➜  OK
fc⊥ = = 138.0 psi
 fc⊥ = 138.0 psi < Fc⊥x' = 378.55 psi  (CSI = 0.36)   ➜  OK
7/12/2022 6
