Grade: SP DSS
Design Span (L): 3.33 ft.
Clear Span: 3.17 ft.
Total Span: 3.50 ft.
Bearing (lb): 2 in.
Live Load: 40 plf
Dead Load: 0 plf
Selfweight: 7.1 lbs
Dist. Selfweight: 2.14 plf
Total Weight: 7.5 lbs
Orientation: Horizontal
Beam Design 2022A518
7/11/2022 1
SP DSS 2400 1650 175 660 1900 1900000 690000 0.55
7/11/2022 2
Volumetotal = N[A x (L + lb)] = 1 x [8.25 x (40.00 + 2)] x (12 in./ft.)3 = 0.20 ft3
Volumespan = N[A x L] = 1 x [8.25 x 40.00] x (12 in./ft.)3 = 0.19 ft3
Total Weight (WT) = ρw x Volumetotal = 37.33 x 0.20 = 7.5 lbs
Self Weight (WS) = ρw x Volumespan = 37.33 x 0.19 = 7.1 lbs
Distributed Self Weight (ws) = = 2.14 plf
40 plf
0 plf
ws = 2.14 plf
3.33 ft.
3.17 ft.
3.50 ft.
73.74 lbs
73.74 lbs
7/11/2022 3
Fby' = (2400)(1.00)(1)(1)(1)(1)(1.15)(1)(1) = 2760.0 psi
fb = = 340.4 psi
 fb = 340.4 psi < Fby' = 2760.0 psi  (CSI = 0.12)   ➜  OK
7/11/2022 4
Fvy' = (175)(1.00)(1)(1)(1) = 175.00 psi
fv* = = 11.81 psi
 fv* = 11.81 psi < Fvy' = 175.00 psi  (CSI = 0.07)   ➜  OK
fv = = 12.77 psi
 fv = 12.77 psi < Fvy' = 175.00 psi  (CSI = 0.07)   ➜  OK
Ey' = Ey(CM)(Ct)(Ci) = 1900000(1)(1)(1) = 1900000 psi
7/11/2022 5
ΔLL = = 0.04 in.
(L/d)LL = 40.00 / 0.04 = 1058
 ΔLL = 0.04 in = L/1058 < L/180   ➜  OK
ΔTL = = 0.04 in.
(L/d)TL = 40.00 / 0.04 = 1005
 ΔTL = 0.04 in = L/1005 < L/120   ➜  OK
Fc⊥y' = (660)(1)(1)(1) = 660.00 psi
Ab = d x lb = 5.5 x 2 = 11.00 in2
fc⊥ = = 6.7 psi
 fc⊥ = 6.7 psi < Fc⊥y' = 660.00 psi  (CSI = 0.01)   ➜  OK
7/11/2022 6
