Beam Design - Deck Joist Design
Design Span (L): 4.75 ft.
Clear Span: 4.50 ft.
Total Span: 5.00 ft.
Dead Load: 10 plf
Selfweight: 17.7 lbs
Dist. Selfweight: 3.72 plf
Total Weight: 18.6 lbs
CL Beam Stability Factor 0.980 - - - - -
Beam Design Joe Klatt South Bend, IN 1
7/9/2022 1
7/9/2022 2
= 38.58 lbs/ft3
Volumetotal = N[A x (L + lb)] = 1 x [13.88 x (57.00 + 3)] x (12 in./ft.)3 = 0.48 ft3
Volumespan = N[A x L] = 1 x [13.88 x 57.00] x (12 in./ft.)3 = 0.46 ft3
Total Weight (WT) = ρw x Volumetotal = 38.58 x 0.48 = 18.6 lbs
Self Weight (WS) = ρw x Volumespan = 38.58 x 0.46 = 17.7 lbs
Distributed Self Weight (ws) = = 3.72 plf
10 plf
ws = 3.72 plf
4.75 ft.
4.50 ft.
5.00 ft.
284.29 lbs
284.29 lbs
7/9/2022 3
lu/d = = 2.59
Rb = = 14.26
 Rb = 14.26 < 50   ➜  OK
7/9/2022 4
Eminy' = Eminy(CM)(Ct)(Ci) = 510000(0.9)(1)(1) = 459000 psi
FbE = = 2709.92 psi
Fbx* = Fbx(CD)(CM)(Ct)(CF)(Ci)(Cr) = (800)(1.00)(1)(1)(1)(1)(1) = 800.00 psi
CL =   = 0.980
Fbx' = (800)(1.00)(1)(1)(0.980)(1)(1)(1) = 784.0 psi
fb = = 179.9 psi
 fb = 179.9 psi < Fbx' = 784.0 psi  (CSI = 0.23)   ➜  OK
fv* = = 19.72 psi
 fv* = 19.72 psi < Fvx' = 169.75 psi  (CSI = 0.12)   ➜  OK
fv = = 29.20 psi
 fv = 29.20 psi < Fvx' = 169.75 psi  (CSI = 0.17)   ➜  OK
7/9/2022 5
ΔLL = = 0.01 in.
(L/d)LL = 57.00 / 0.01 = 6203
 ΔLL = 0.01 in = L/6203 < L/360   ➜  OK
ΔTL = = 0.01 in.
(L/d)TL = 57.00 / 0.01 = 5455
 ΔTL = 0.01 in = L/5455 < L/240   ➜  OK
fc⊥ = = 63.2 psi
 fc⊥ = 63.2 psi < Fc⊥x' = 378.55 psi  (CSI = 0.17)   ➜  OK
7/9/2022 6
